Memory for an ISC peer health check message could not be allocated because the system is low on memory. This will result in the MLAG peer node incorrectly declaring this node as down and block traffic on the ISC intended to MLAG ports.
Reducing the system configuration may help reclaim memory.
Error
Failed to allocate health check message buffer of %size% bytes
| Name | Type |
| size | uInt32 |
